Orbi WiFi 7 RBE973
Reply
X4S File copied over the network fail MD5 checksum and are corrupted
TBy
Tutor
Tutor
 I have the X4S configured as an access point. I have a PC connected to the X4S via ethernet cable. Files copied over the network consistently fail MD5 checksum. I've searched and found a related post with no resolution, other than configuring the router as a normal router and not as an AP which is not a fix but a workaround and I need the AP configuration.  Link to previous thread
I'm running the latest firmware v1.0.1.52.
I replaced the router and all files copied are without error, so it is definitely a problem with the router. Very frustrated as I'm having to go back and restore backups due to the corrupted files but not everything was backed up.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 11
Accepted Solutions
KristinaS
Apprentice
Re: X4S File copied over the network fail MD5 checksum and are corrupted
by the way for a test you just need to disconnect you cable from internet port and to attach it to the internet port. two seconds. and i beat you will not have such md5sum problems anymore.
Message 8 of 11
All Replies
KristinaS
Apprentice
you have to use the only lan ports if your router is in ap mode. no wan port. i guess you are using wan so it is a reason.
Message 2 of 11
TBy
Tutor
Tutor
 The manual states to connect the X4S Internet port to the LAN port of the other router which is how it is/was configured. I take it the "Internet" port is what you reference by "WAN" port. Is there reference that your method should work?
Message 3 of 11
Kitsap
Master
Maybe the error is in the manual.  Would it be reasonable to use the second configuration and run a test?
Message 4 of 11
antinode
Guru
> [...] Files copied over the network consistently fail MD5 checksum.
   "copied" how, exactly?  From what to what (computer systems, storage
devices, ...)?  Have the source and destination files the same size?
   Are the file data simply passing through the router, or do you have a
USB storage device connected to the router, or what?
   Even for Netgear, corrupting data on the fly seems like the kind of
bug which might be caught in even minimal testing.
> [...] I replaced the router and all files copied are without error, so
> it is definitely a problem with the router. [...]
   Or something else changed at the same time.
> [...] you have to use the only lan ports if your router is in ap mode.
   Not really.
> Maybe the error is in the manual. [...]
   Or, maybe not.  On modern Netgear routers with a one-step "AP Mode"
option, the WAN/Internet port is reconfigured as essentially another LAN
port.  On a router without a one-step WAP option, the WAN port is on the
wrong side of the LAN-WAN boundary, and is not used.
   There should be no harm in trying another LAN port instead of the
WAN/Internet port.  I wouldn't expect much to change, but that's what
experiments are for.
Message 5 of 11
TBy
Tutor
Tutor
Answers Below
 Copied file with Windows Explorer, TeraCopy and RoboCopy. The file sizes are the same when properties are checked using Windows 10 properties dialogue. Copies from one computer SSD over the network to another computer's SSD, HDD or USB HDD resulted in corruption. Files failed TeraCopy and QuickHash MD5 checksum verification
 No USB attached devices, just router configured as AP
Corruption became evident on video and audio files as video had intermittent tearing, pixelation or freezing. Audio file would occasionally have drop outs, clicks or pops. It took awhile to rule out all other possibilities leading to the router. i.e. RAM, Bad HDD/SDD Sectors, configurations, etc... I hadn't transfered and used executables
Nothing changed...I did a few copies over the network, verified MD5 checksums failed. Replaced router configured as AP with another router configured as AP, ran the exact same copies and all MD5 checksum passed.
   Not really.
I'll give it a shot but my hopes aren't up.
Message 6 of 11
KristinaS
Apprentice
i had the same issue  with my r7800 in ap mode. there were broken files transferring them with readyshare or ftp. manual is wrong. i have connected my router to the lan port instead of internet port and now it works as it have to do. i am using it connected to lan port during one year and do not have such problems amymore. one year of testing is enough?
Message 7 of 11
KristinaS
Apprentice
Message 8 of 11
TBy
Tutor
Tutor
OK! Using just the LAN ports and not the "Internet" port fixed the problem. I wish I would have thought (or known) just to move the ethernet cable before taking down and swapping out the router.
Appreciate all in this thread and patience! I hate when the manual is wrong!
Message 9 of 11
antinode
Guru
> problem. [...]
   Interesting.
> [...] I hate when the manual is wrong!
   Or when there's a hardware/firmware problem such that the router
fails to perform as designed/specified.  (When your car doesn't start,
do you complain about the car or the car's owner's manual?)
Message 10 of 11
KristinaS
Apprentice
i think it is rather bug in the stock ng firmware. but using lan port is a workaround. by the way i would advice to use voxels fw
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-53sf-1-0-2-53sf-kf-updated...
it is like a stock but with fixed bugs and faster/stable. could be flashed over stock and all your current settings are kept.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 6021 views
  • 6 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
