Orbi WiFi 7 RBE973
Reply
X6-R8000 in continuous restart loop
wkus
Follower
Hi, can someone help me?
The Nighthawk R8000 is in continuous restart loop.
It happened all of a sudden, may I know what is wrong with it and how to fix it?
I have tried contacting the local netgear service centre, but they are unwilling to service the router as it was not bought here (in this country).
Your advise is greatly appreciated.
Thank you.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
Guru
Re: X6-R8000 in continuous restart loop
Have you tried a factory reset? Push and hold reset for up to 30 seconds while its powered on.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 2 of 3
Take us through what you see when this happens.
What do the LEDs on the front look like?
Does the power LED ever get to show "white"?
I'd also check the power adapter. These things can go wrong. If you have a spare with the same output, try that.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 668 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
