- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
connected devices bandwidth
- Mark as New
- Bookmark
- Subscribe
- Permalink
Under Connected Devices it used to show how much bandwidth each device was using. This was incredibly useful for diagnosing network issues, which were often caused by 1 system doing windows updates which killed the connection for all other devices.
This information now seems to have gone and I cannot find it anywhere else. I can only assume Netgear removed it in the last update, as if I wasn't annoyed enough at all the other problems with this rubbish firmware. Can anyone confirm, and if so, any suggestions on other solutions ?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
nevermind I solved it, you need to have QOS enabled for this feature.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: connected devices bandwidth
Hi CaptObvious,
Which firmware did you use that you were still able to see the feature?
- Mark as New
- Bookmark
- Subscribe
- Permalink
