- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
emailing does not clear the log - R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since the 1.0.5 release in November, emailing the log file has changed behavior. Prior to that release, it cleared the log after sending. Now it does not.
I email the log to myself every night at midnight. It used to have only that day's activity. Now, each day I get the entire log, back to the last reset. At least there should be a checkbox option to clear on send.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you're willing to reset to factory defaults I think you'll find 1.0.6.28 works much better. Some people have reported problems I haven't experianced ANY so far and I'm on my PC's more than I should be. My log is e-mailed daily with only the info since last e-mailed log.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: emailing does not clear the log - R7000
Thanks, Searay, that's useful information.
I am running the 1.0.6.28 firmware, and I did a reset when I installed it. The fact that yours is running fine means that something is messed up with my configuration. I'll try another reset and report back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
based on recent events I would revert to 1.0.4.30
