iakst2
Mar 09, 2021Follower
looking for internet extender for Nighthawk® DOCSIS® 3.1 6Gbps Two-in-one Cable Modem + WiFi 6 Route
Hello, I have a
Nighthawk® DOCSIS® 3.1 6Gbps Two-in-one Cable Modem + WiFi 6 Router
and am looking for internet extender to work with this modem-router. It is located on the second floor of my house, and I'd like to extend fast speed internet to my basement. Would this extender work:
Dual-band WiFi 6 Mesh Extender, 1.8Gbps, Wall-plug, Internal Antenna
or do you recommend a different device?
Thanks
1 Reply
Sort By
Anything designed for the purpose should work.
Start here and feed in your needs:
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
It should, but that is a description, not a Netgear model number.
