- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
weird wifi behavior
- Mark as New
- Bookmark
- Subscribe
- Permalink
weird wifi behavior
I just bought these and it was an easy to setup but now I'm having issues connecting other devices. All my ipads, iphones connect, but i have to hardwire the satillites to my home pc and work pc for some reason
Keeps saying the password has changed. i verified the password is correct, the SSID is correct. I also have Nordic Track that uses WIFI and it can't connect either.
Any ideas why i have to hardwire to the satillites? why I'm getting incorrect password?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: weird wifi behavior
what are "these"?
You didn't put what router you bought.
What firmare is on them?
What modem/gateway are they connected to?
Details are key to helping you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Its a RBR750
firmware V4.6.3.7
Connected to a direct fiber connection via frontier.n It s a 1gb connection.
But I think I may have figured it out There is a network key for wireless i think that's the wifi password? Going to test it out and if thats it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Looks like that fixed it weird thing is though, other devices are using my origina password. I guess the system uses paswords for different scenerios?
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not so much different scenarios as different actions.
Netgear makes life interesting by having all manner of passwords. There is the one into the router's controls, then there are those to get into the router's wifi, and then there any that you use to get into this Community and/or MyNetgear.
Different passwords pop up at different times, depending on how you connect to the device and where you are trying to access from, your local network or somewhere else on the Internet. (Previously known as Remote Access, that's now called Anywhere Access.)
If you are talking about access to the browser's graphical user interface (GUI), the router's controls, these are on the label for your device, along with the default wifi login details. The username is fixed at admin. The default password is password.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks again !
