Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Amber ligth on MS60
iamgeorge
Guide
Amber ligth on MS60
Hi,
When i sync between my MR60(router) and MS60(satellite) of my MK62, If both of them are placed near, then both of them will show blue light. But when i keep my satellite in a differenct area of my home(range is available in this area), the satellite is showing amber light. I tried wired backhaul using rj45 running between router and satellite, but still it shows amber, but sometimes shows blue.
What is this problem?
Thanks in advance
Message 1 of 4
Christian_R
NETGEAR Employee Retired
Re: Amber ligth on MS60
Hello,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 4
Priceawolowitz
Initiate
NetGear products made recently have been horrible and are no longer at the same level as they used to be. On top of that paying for the additional NetGear support has been completely useless and support never has the answers. All the new WiFi6 mesh products have the same underlying problem where the satellites fail to communicate with the router and the connection fails. This problem is known to NetGear in both the Nighthawk and Orbi products but they do not have an answer and con you into buying their extended “worthless” support.
Message 3 of 4
JoseEC
Initiate
I have the MK62 Product (MR60 and MS60).
I was able to solve this by unplugging and replugging the MS60 satellite into the power outlet, then inserting a pin into the hole on the back of the satellite to do a Hard Reset.
The satellite came on with a blinking white LED, then it changed to amber for 1 minute, then it went to blue.
Can you try this and see if it solves your issue?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3606 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
