- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't Turn Remote Management Off - MR60 Mesh Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
If anyone can help I appreciate it. I have the latest firmware. I am just trying to turn off the Remove Management.
When I unselect and then hit Apply it does not save the setting, and turns it back on... Anyone have any suggestions? I have to get it turned off to pass a PCI compliance test. Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't Turn Remote Management Off - MR60 Mesh Router
If you find yourself unable to disable remote management on your MR60 Mesh Router, you can try the following steps:
- Open a web browser and enter the router's IP address to access its settings.
- Log in using your credentials.
- Within the settings interface, locate the section related to remote management.
- Make sure to select the option for turning off or disabling remote management.
- If you encounter persistent issues, it might be helpful to check for any available firmware updates that could resolve the problem.
- Alternatively, seeking assistance from Netgear's support team could provide further guidance in addressing the remote management concern on your MR60 Mesh Router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You already have the latest firmware, but there have been rare cases where reinstalling the firmware can mend minor errors in it.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
You could also see if a reset "unsticks" the controls.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wow, thank you so much!!! I will try and first manually redo the firmware, and then if that doesn't allow me to turn off remote management, do a factory reset, correct?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks again, sadly manually reinstalling the firmware doesn't fix it ;-(
Next I should try just factory reset?
It's so odd I can deselect the option, but when I go to save, it turns it back on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What browser are you using? Try MS Edge or Firefox or Opera.
Be sure to clear out all browser caches before entering the MRs web page.
Definitely try a Factory Reset and setup from scratch. Do not load any saved backups from file.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks so much I tried a new install of Firefox same issue. I uncheck the box, hit save, it comes back.
At this point, sound like I need to do factory reset?
Do you think it's not possible to turn off Remote Management?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have a complicated configuration on your router? If so, it might be a good idea to save it:
Then, after you reset the router, don't waste time by doing anything beyond trying to turn off Remote Management. You might not even need to get on line.
If that works, great, go ahead and reconfigure the router.
If it doesn't work, then you know that the reset does not work. So you could restore your configuration on the grounds that it isn't the issue.
One other thought is that something change in a earlier firmware update. (It has happened.) So you could try installing an earlier firmware to see if that unsticks the on/off toggle for Remote Management.
- Mark as New
- Bookmark
- Subscribe
- Permalink
THANK YOU SO MUCH, this WORKED!!!
I erased all router settings, then hit the factory reset button on the router. Then I reconnected it from scratch. Even though I did have the latest firmware before, this time the "remote management" option disappeared!!!
I am good to go and thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
