- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Diasble Daisy Chain Nighthawk MR80
- Mark as New
- Bookmark
- Subscribe
- Permalink
Total newbie here. I cannot for the life of me figure out how to turn off the wireless daisy chain on my MR80 nighthawk setup. The orbi instructions do not work on the nighthawk, but on the netgear website it says you can configure in daisy chain or star setup. My system keeps switching back and forth, and when it is in a daisy chain configuration i cannot get fast speeds in this configuration. Any help would be greatly appreciated
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Diasble Daisy Chain Nighthawk MR80
How many MS do you have deployed?
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-W... 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
MR80 V1.1.6.14
(2) MS80 satellites v1.1.6.14
Netgear Nighthawk CM2000
2 Satellites
4,400 sf
My best guess is that they are over 30 ft apart, Router is on main floor, one satellite in master on upper floor and one satellite in basement. Any suggestions to change the settings to not allow the satellites to daisy chain?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are the MS placed on each side of where the MR is located? No out in a line from each other?
If there in a star formation, they should not connect in Daisy Chain
Placement is key here.
Might turn off one of the MR for 5 minutes then back ON and see.
I presume this is in the NH app?
I don't know if there is a web page option for Daisy Chain, might look under Advanced Tab/Advanced Settings/Wireless Settings on the MR.
