- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Homepod mini only works with my iPhone 11 Pro on MS60 satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m so frustrated with this connection issue. Any idea on this? Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I know iphones are now using random mac addresses. If you disable that option, and connect/reconnect a few times or re-associate the homepod, does it work?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Homepod mini only works with my iPhone 11 Pro on MS60 satellite
Your statement makes it seem like it can be found both ways but your title makes it sound different.
1. what firmware is on the router and on the satellites?
2. what modem/gateway is the router connected to?
3. have you contacted apple about this at all?
- Mark as New
- Bookmark
- Subscribe
- Permalink
1. V1.1.6.122 on both router and satellite
2. I’m using Huawei HG8040 modem which is provided by the ISP
3. Not yet. I just found this problem so wanted to see if any MR60 user having the same problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wow.. it really works! Much appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah, sucks when apple's own "security measures" break their own equipment or mess it up standard router setups. Not the first time it's happened
