Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
MR60 - Youtube slow to load
Cyberchill
Tutor
When I open youtube, there is a delay before the ad or content loads.  This may be 15-30 seconds or more.  This happens regardless of if it is a computer or a mobile device on the wifi network.  When I disconnect and go with 5G on my phone, there is no delay. This does not seem to impact other streaming content (Netflix, Disney+ etc.).
I assume there is some setting that I need to change (or not, if it is protecting me).  Looking for advice.
Thanks!
(NOTE: Posted in wrong group.  Reposting in the right place, sorry!)
Model: XRM570|Nighthawk Pro Gaming Router and Mesh WiFi System
Message 1 of 6
Accepted Solutions
Guru
Re: MR60 - Youtube slow to load
that fibre is connected to some ONT.
What ONT is it?
Do you have IPv6 enabled?
Are you using netgear armor, parental controls?
Have you tried using a different dns from the stock one? you can try googles at 8.8.8.8 or 8.8.4.4
Message 4 of 6
All Replies
Guru
Message 2 of 6
Cyberchill
Tutor
Running the latest: V1.1.6.122_2.0.58
I have FTH which goes straight into the Router.  There is no modem.
Thanks!
Message 3 of 6
Guru
What ONT is it?
Message 4 of 6
Cyberchill
Tutor
So I have no idea where the ONT is, or what model it is.  Likely it is in a box near the curb.  My provider is MetroNet, formerly Jaguar Communications.  I will likely contact them to see if they have ideas as well.  Essentially I have a Cat6 cable going into my NG and it is configured with PPPoE.
IPV6 is enabled with a 6to4 tunnel and auto everything after that.
I am not using Armor or Circle.
I'll change the DNS to see if that helps.
Thanks!
Message 5 of 6
Cyberchill
Tutor
It was indeed the DNS setting.  Once changing them to 8.8.8.8 and 8.8.4.4 it was like magic.  Thank you!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2171 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
