Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
MR60 constantly needs reset to achieve speed
Rgman38
Follower
Hello all,
I have the MR60 mesh Wi-Fi 6 system. It’s probably 3 years old at this time. Until now, I’ve experienced zero problems. Unfortunately, just recently I noticed my speeds are constantly slower compared to my history. Once I power cycle the router, the speeds immediately return to normal. However, this reset is required more and more frequently. We’re a house of gamers so I’m resetting it 2-3 times daily currently. My series x is hardwired into the router and it’s speeds seems to be consistently fast. My speed to the router, tested in the nighthawk app, also seems to be consistently fast which xfinity has also confirmed. It just seems to be my Wi-Fi only. My firmware is up to date. Any ideas?
Message 1 of 2
Guru
Re: MR60 constantly needs reset to achieve speed
1. what modem/gateway are you using?
2. what actual firmware version are you on for the router and the satellites (a number)?
3. do you notice a difference in speed when tested on the router versus the satellites?
4. Did you ever try a factory reset and new install?
5. do you have ipv6 enabled?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 582 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
