- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
MR60 performance issue in AP mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: MR60 performance issue in AP mode
Try a factory reset and setup from scratch then configure AP mode?
What CAT# LAN cable are you using? CAT6 is commended.
Be sure to disable any wifi radios on the ISP modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like router mode works best.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wanted to test this as well:
MR Router mode:
iPhone and Android pad:
MR AP mode:
4 feet distance between MR and test devices.
Ethernet showed over 900Mpbs in router and AP mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possible something on the upstream router is causing the MR to degrade and perform slower than expected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Sputnik91 wrote:
I decided to use the router built into my modem to utilize it's 2.5gb port (I have 1200mbps internet) so I put the AX1800 system into AP mode.
Do you have anything that can use speeds over 1000 Mbps?
The MK system can't. Its WAN and LAN ports are limited to 1000 Mbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
