× Our systems will undergo a planned maintenance on Sunday, May 19, 2024, between 12:00 AM and 02:00 AM Pacific Time. During the maintenance window, you will not be able to log in to your MyNETGEAR account (including apps), renew a subscription, or register a product. However, you will still be able to use guest checkout to purchase a new product or subscription service. Updates will be posted to Status.NETGEAR.com. We apologize for any inconvenience this may cause.
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
MR60 stopped working
Nighthawk_25
Hi all,
Everything was fine yesterday, today have a white flashing light on the router.
Have tried resetting it no effect. It’s 15 months old. Not had a problem with it before.
Have internet from our router (eero) so it’s definitely the MR60 that’s just given up.
Anything else I can try before binning it and buying a non NetGear replacement WiFi mesh?
Thanks
Message 1 of 6
Accepted Solutions
Guru
Re: MR60 stopped working
Can you access the MRs web page at all with a wired PC?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Message 2 of 6
All Replies
Guru
Message 2 of 6
Nighthawk_25
Thanks.
A third reset stopped the white light flashing.
All went blue, great, but nothing actually connected to the internet. Went through the setup and still the same.
Walked away for 10 mins and it prompted me to set up again and all is back working.
Seems to be connecting again now.
Thanks for the help.
Message 3 of 6
Guru
Was the system auto FW updated or did you manually update FW?
Good to hear.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 4 of 6
Nighthawk_25
It said firmware was up to date.
I have a feeling it tried to update the FW overnight and that’s what caused it to go offline. Perhaps it finished installing but hit a problem and when the reset finally kicked in it was all up to date.
Thanks for the backup link.
Message 5 of 6
Guru
Ok, Ya I had a hunch that was the problem. Not the first time AU has caused problems. Why I manually update my systems.
I recommend check to see under Router Update that AU can be disabled on the MRs web page under Advanced Tab. I believe it can be.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2405 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
