Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Netgear MR60 with Verizon G3100 router
pappyg
Follower
I bought the Netgear MR60 back in January and my complimentary tech support has expired. At the time I was using Verizon FIOS with whatever modem came out 3-4 years ago. I configured my Netgear MR60 and satellite device and it seemed to have addressed my issue with getting a strong signal throughout my house over the past 4 months. HOWEVER, I just upgraded to the newer Verizon G3100 router and now I cannot get my MR60 to connect to it. To be candid, networking and wifi is not my area of expertise by a long shot - I was just looking to boost my signal so we would stop getting buffering while streaming Hulu. I don't even know if I still need the mesh devices but I figured I bought them so I may as well hook them up. But again, my Netgear setup app says it cannot find the new router. I put in the new name and password, but it says "We can't find your Router". Hitting the reconnect button results in the same message and clicking the "Connect to a different product" link just results in a blank page. I am also seeing a Configuration Error page in the app where it tells me to check my wifi connection and try again, to no avail. I guess I need to know if I am just spinning my wheels because the netgear device is not compatible with the new verizon router. Please advise. Thanks.
Message 1 of 2
Guru
Re: Netgear MR60 with Verizon G3100 router
The G3100 either needs to be in passthrough/modem only mode or the netgear in access point mode.
Its a modem/router combo device and causes a double nat in default mode.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-M...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1179 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
