- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NightHawk Mesh WiFi 6 System
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there anywhere to change the NightHawk Mesh WiFi 6 System to operate both on 2.4g and 5g? According to the box, I am supposed to be able to, but can't find it in the NightHawk phone app (android).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NightHawk Mesh WiFi 6 System
By default 2.4 and 5Ghz is working in a single SSID configuration.
You can make it work separately: https://kb.netgear.com/000063027/Can-I-create-separate-2-4GHz-and-5GHz-SSIDs-on-my-Nighthawk-Tri-ban...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you mean you want to separate them into two bands? 2.4 GHz and 5 GHz?
By design they are both there, but using the same login credentials.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the manual for struff on WiFi settings.
