Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk MK62 Questions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-02-04
12:10 PM
2021-02-04
12:10 PM
Hello,
I've found some conflicting data on a few questions that may be simply because the firmware has evolved and I'm reading old threads. I was hoping a current owner can weigh in.
- I would like to deploy a mesh solution that be put in bridge/L2 mode without breaking some of other features I need
- I would like to have a 'guest' SSID in addition to the primary SSID. It would like this to be a different IP subnet and it would be even better if I can control/limit guest-to-guest communication.
I found a thread that said a 2nd SSID was not supported at all but the datasheet says yes.
It's also tough to understand what features break when you disable the IP router function for any mesh WLAN solution.
Appreicate any feedback.
Thanks
Bob
Message 1 of 1
Top Contributors
User | Count |
2 | |
1 | |
1 | |
1 | |
1 |
Announcements
