- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk MR60 Disconnecting linked devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk MR60 Disconnecting linked devices
@Definitely123 wrote:
The camera will all of a sudden disconnect, and in order for me to have it work again i have to reset the nighthawks. The wifi and everything else still work, it just essentially “kicks off” certain devices.
How is the camera connected to the satellite? Wired or wifi?
How did you work out that the satellite is responsible for kicking off devices? Any chance that it is the camera that is losing the connection.
You mention "certain devices". Does that mean that everything else stays connected? That would suggest that it is a device thing rather than the satellite.
When you say you have to "reset the nighthawks", is that reset as in "factory reset" or reboot as in power off and on?
I have found that a satellite reboot can sometimes recover lost connections.
What firmware version do you have on the MK62 devices?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It’s almost like it is blocking it once I reboot everything , as in unplug and reset it l...
That sentences is hard to follow.
By "blocking it once I reboot everything" should that be "blocking it until I reboot everything"?
Is that in "unplug and reboot" or are you using the reset button on the back?
Reset has a specific meaning in router talk.
And the other questions? They are there for a reason.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry for the confusion I did a reboot from the Nighthawk app.
Good to rule out the reset. That is really drastic and isn't something you want to do often.
How about the rest of my message?
What is he make and model number of the modem/gateway/ONT that sits between this router and the Internet.
