- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk MR60 Mesh Wifi routers/satelites not working normally with any update after V1.0.6.116
- Mark as New
- Bookmark
- Subscribe
- Permalink
hello , im using Nighthawk MR60 Mesh Wifi routers/satelites from two yers , my Nighthawk not working normally with any version after V1.0.6.116 ,
. Devices not connected to wifi after update
. or connected few minutes and return to disconnect
I tried this versions
Version 1,1,6,124
Version 1,1,6,122
Version 1,1,6,124
Version 1,1,7,132
I tried erase setting but same issue
Anyone have an idea to solve my problem ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk MR60 Mesh Wifi routers/satelites not working normally with any update after V1.0.6.116
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-W... 📡
Please try v.134:
Manually download the files and use a wired PC and web browser to update the MS first then the MR lastly using there web pages. After FW is loaded and the system is back to ready, power OFF then back ON then factory reset the MR and setup from scratch.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When downgraded version to V1.0.6.116 and it works perfectly
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please give more details of "not working normally with any update after V1.0.6.116"
What are you seeing and explain what is happening.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 20 wifi devices , after the update some devices not connect to wifi ( amazon dot , xiaomi ceiling light ) ,
some devices ( iPhone , MacBook , Samsung tv ) connect few minutes and return to disconnect
The device keeps trying to connect to the network but does not connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS🛰️ to begin with depending upon building materials when wirelessly connected.️
What channels are you using?
How is advanced wifi configured on the MR?
Are you factory resetting the system and setting up from scratch after last FW update attempt?
- Mark as New
- Bookmark
- Subscribe
- Permalink
internet Service Provider pppoe
LAN cable CAT6
39 fet almost ( All devices are not more than 9 feet away from the router or satellite )
one or two wifi neighbors
yes i factory resetting the system and setting up after update
- Mark as New
- Bookmark
- Subscribe
- Permalink
And you did update the MS first before the MR right?
How many MS do you have deployed?
So 39 feet between the MR and MS?
Lets try changing to channel 1 and 40 on the MR.
Also lets set 40Mhz co-existence only on the MR under Advanced Tab/Advanced Settings/Wireless Settings
Be sure that Beamforming and MiMo are enabled here as well.
There a brand and model# of the ISP modem that the MR is connected too?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Now i updated to 134
- Update MS first and MR
- erase the configuration settings
Same problem ( 2 Samsung tv , amazon Dot , MacBook , xiaomi ceiling light ) not connect
tried
- Change channel to 2/36
- Change channel 1/40
Same problem
- tried reboot ( MS disconnect )
- The failed attempts took 3 hours, in which I tried more than one method, but to no avail
- downgraded to V1.0.6.116 ( All devices are back connected normally)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried changing the SSID name from the default to some thing else. Something custom?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My home 450 Ft
I tried change SSID but same problem
I tried create customize wifi and same problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok well for that size of home, not sure if the MS would be needed. The MR can cover more then that.
Did you try with out the MS connected?
You might open a support ticket with NG support and let them know about this as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it goes...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I created a ticket yesterday, but no response yet
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll pass this on to NG for review.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi sir , hello , im using Nighthawk MR60 Mesh Wifi routers/satelites from two yers , my Nighthawk not working normally with any version after V1.0.6.116 ,
. 1.1.6.124
. 1.1.6.122
. 1.1.6.124
. 1.1.7.132
. 1.1.7.134
Do you have an idea or solution for this
https://community.netgear.com/t5/Nighthawk-Wi-Fi-6-AX-Mesh/Nighthawk-MR60-Mesh-Wifi-routers-satelite...
- Mark as New
- Bookmark
- Subscribe
- Permalink
You need to send @DarrenM < a Private message by selecting his user name and going to his profile and select Send Message and send him a message there. Don't start a new forum thread post.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
