Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Nighthawk MR80 - admin portal shows empty port forwarding table although there are records populated
nbeasy
I have a Nighthawk MR80 router with firmware V1.1.6.14_3.1.101.
The admin portal shows empty port forwarding table although I have populated records and if I try to create something I know already exists (but is not showing), I can confirm it exists because on trying to add the service, I get an error that says service already exists.  But the table still shows as empty.
Message 1 of 8
Accepted Solutions
nbeasy
Re: Nighthawk MR80 - admin portal shows empty port forwarding table although there are records popul
Resetting the router solved.  Thanks.  A pain to reset all the devices and settings, but hopefully not an issue the happens again.
Message 7 of 8
All Replies
Guru
What browser are you using? Different browser show same thing?
Post a screen capture of what your seeing please.
Message 2 of 8
nbeasy
Attempted with chrome and safari.
Message 3 of 8
Guru
And this is one a PC monitor and browser zoom factor is at 100%. What happens if you zoom out or reduce zoom factor by 25%? Same thing?
Is this seen across more than one PC?
What OS version are you using?
Message 4 of 8
nbeasy
Yea, changing the zoom of the browser or widening it doesnt change.  Tried on a few different devices (mac laptop on wifi, mac desktop connected on ethernet, and android using chrome browser in desktop mode) and using both safari and chrome.
Message 5 of 8
Guru
Message 6 of 8
nbeasy
Message 7 of 8
Guru
Glad you got it working. Be sure to save off a new back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 8 of 8
Discussion stats
  • 7 replies
  • 1425 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
