- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Slow internet while im trying to play my game
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a mk63. The modem BGW210-700 is from att and it is also a router. The firmware version of my mk63 is v1.1.7.134 which is the latest version and im tired of this lsow internet while im trying to play my game.. I spend money every month so I can be satisfied with my internet but don’t get 1/4 of it! It’s insane
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Slow internet while im trying to play my game
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try option #2 first...
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-W... 📡
Recommend connecting gaming devices via ethernet for best and optimal gaming performances.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recommend seeking help on determining that with you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router.
You are not the first person to want to use that device in bridge mode:
Solved: How do I setup bridge mode in the ARRIS BGW210-700 - NETGEAR Communities
More generally try this:
bgw210-700 bridge mode - Google Search
This may not speed up your Internet service – what speed are you paying for ? – but it is the first thing to fix. Then you can start investigating what else may be going on.
You don't say what you are using to game but remember, when gaming, wifi is never going to be as good as a wired connection. Too much depends on the speed of whatever wifi clients you are using.
User | Count |
2 | |
2 | |
1 | |
1 | |
1 |
