- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
What's the difference between an MK70 and a MK63
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I helped a friend set up his #MK70 router with the two satellites. Seemed like a nice system
Now I found a good price on an #MK63 -100NAR, however, after a lot of searching, I have not been able to find out what the main differences between those two models are.
Does anybody have an overview of the different models?
Thanks in advance,
istrebitjel
EDIT: I just figured out MK vs MR with another answer here! But the main question still stands 🙂
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
both are dual band systems but the MK70 system supports 160hz wide channels versus the MK60 is only 80hz wide.
Meaning the 70 series is a little faster.
If I had to choose, I'd look at the MK80 series as its a triband with the dedicated backaul.
i'm a fan of the dedicated backhaul.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: What's the difference between an MK70 and a MK63
MK(6or7)X is a bundle of an MR(6or7) router plus X (usually 2 or 3) MS satellites.
To work out the technical differences check the relevant data sheets.
Visit the support pages:
Support | NETGEAR
Feed in th model numbers and check the documentation for your hardware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
