× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
AC7000
riodwardlx
Initiate
AC7000
Got the A7000  AC1900, and love it. Decided to renew the Armor security. I went through the link to Bitdefender and completed the transaction, however I cannot find a way to connect that with my router. The nighthawk app and the logging in on the computer continues to show that the Armor security is expired. Anybody with any thoughts. Bitdefender shows my purchase complete.
Thanks, Dave.
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 2
Re: AC7000
That is a USB wifi adapter. It doesn't do Armor. You probably have something else.
Do you mean R7000? Something else?
Armor has its own bolt hole:
NETGEAR Armor - NETGEAR Communities
You might do better to try there.
See also:
What is the NETGEAR Armor Bitdefender Total Security feature? | Answer | NETGEAR Support
Message 2 of 2
Discussion stats
  • 1 reply
  • 743 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
