Orbi WiFi 7 RBE973
Reply
AX120 don't start up only blinking power light after firmware update V1.0.1.114
CBV
Tutor
Tutor
Today I did a firmrware update V1.0.1.114 to my AX120, after 30 minutes I went to check my router and it was not started up, only power ligh is blinkig and reset button is not working.
Any ideas on how to solve it?
Thanks
Regards
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
Re: AX120 don't start up only blinking power light after firmware update V1.0.1.114
@CBV wrote:
Today I did a firmrware update V1.0.1.114 to my AX120, after 30 minutes I went to check my router and it was not started up, only power light is blinking and reset button is not working.
An indicator of corrupt firmware. (See the manual for what the LEDs mean.)
What colour is it blinking?
Unfortunately, you are probably into TFTP territory.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
TFTP isn't the easiest of manoeuvres, so it might be worth a web search for videos that show how to do it.
netgear router tftp video - Google Search – netgear router tftp video
Take your pick.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1834 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
