× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
CAX30 — Nighthawk AX6 6-Stream WiFi 6 Cable Modem Router
myslad
Whats the maximum dowload speed that we can expect. I have xfinity 1.2 gig connection
I get only 200 MBps, with wired connection?
Any settings need to be tuned?
Message 1 of 12
Guru
Re: CAX30 — Nighthawk AX6 6-Stream WiFi 6 Cable Modem Router
Its a docsis 3.1 device. It should support gig+ speeds.
Do you have a screen snip of the cable connctions page and the event logs?
That lets us check your connection
Message 2 of 12
myslad
Screen grab of Cable connectionScreen grab of Cable connection
Message 3 of 12
Guru
photos can take a bit to be approved as a moderator has to approve them
Message 4 of 12
myslad
Message 5 of 12
myslad
@plemans attaching smaller file size pics.
Advanced Thanks for helping.....
Message 6 of 12
Guru
what device are you testing on ?
What website are you testing on ?
Message 7 of 12
myslad
I am checking in fast.com
Message 8 of 12
myslad
fast.com; using Windows 10 laptop; Wired connection
Message 9 of 12
Guru
Have you tried other sites like speedtest or dslreports?
Message 10 of 12
myslad
speedtest: 208.8 Mbps
https://www.speedtest.net/: 145 Mbps
Message 11 of 12
Guru
Do you have other devices you can hardwire in and test with?
Maybe its a device issue.
What device are you speedtesting on?
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1720 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
