- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot connect Google home to Nighthawk AX8 router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Model RAX75 AX5700
Used at home
Firmware says up to date V1.0.1.70_1.0.20
Cannot connect google home to router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cannot connect Google home to Nighthawk AX8 router
What issues are you having? Just saying it doesn't connect doesn't tell us where its failing in the process, whats going on, what you've tried, or pretty much anything. we need details to help you.
Firmware on your rax?
what modem are you using?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
the google home (not mini) is compatible with 5ghz. Have you tried setting it up on that band?
- Mark as New
- Bookmark
- Subscribe
- Permalink
5ghz doesn't work either. I get internet into my router from my ISP. There is no modem. Clarity Connect points their antennae to their broadcast location a few miles away. The google home worked great with my previous Linksys router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Some of these wifi to the home setups have their own router running (corportate) or a small integrated router into the antenna box.
If this is the case, you could be in a double nat which can cause setup issues.
https://kb.netgear.com/30186/What-is-Double-NAT
have you checked with clarity connect to see if this is the case?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
