× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Cannot disable beamforming on RAXE500 (fw V1.0.12.96_2.0.45)
quite68
In some situations (not sure which ones) I cannot disable beamforming. I uncheck the checkbox and press Apply but after settings are applied the checkbox is checked again.
Any idea what is going on?
Message 1 of 9
Accepted Solutions
quite68
Re: Cannot disable beamforming on RAXE500 (fw V1.0.12.96_2.0.45)
I suspect this is a bug in 1.0.12. I've reverted to 1.0.11 and it's working again.
Message 8 of 9
All Replies
Guru
Is AX mode enabled?
What browser are you using? Try MS EDGE. I just disabled mine and it stayed disabled.
Message 2 of 9
quite68
AX is not enabled.
I'm using Chrome on an Ubuntu machine.
Sometimes disabling Beamforming does work, not sure what the settings difference is between when it works and when it doesn't.
It wasn't a problem with an older fw version.
Message 3 of 9
Guru
Try with Firefox?
I'm using a Windows PC.
Message 4 of 9
quite68
It's the same in Firefox. I doubt it's anything to do with the browser.
My guess is there's something in the fw that says you can't disable Beamforming if X is true, but it doesn't tell you in the web-site it just quietly refuses to disable it.
Message 5 of 9
Guru
Why are you trying to disable beamforming?
Message 6 of 9
Guru
I'm currently using my RAXE with Smart Connect disabled along with AX mode. Might try this as well. I was able to disable and enable it this morning.
Message 7 of 9
quite68
Message 8 of 9
Guru
Wondering if you apply v.96 again over on top if it sticks.
Not sure if it's bug. I'm able to disable and enable Beamforming on mine and I've got v.96 FW loaded.
Message 9 of 9
Discussion stats
  • 8 replies
  • 1386 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
