- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Crazy Problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Crazy Problem
I recently went to AT&T 5G Air for my Internet. Problem is VPN's will not work with their Router and the speed goes down to very close to nothing. I can connect my Nighthawk Model RAX70 to the AT&T Router by cable and I am wondering since I will be connected to my Nighthawk Router if I will once again be able to use a VPN. Thanks for any help or suggestions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Crazy Problem
in my experience, its not going to change the speed because the bottleneck is the att device.
You're always welcome to try it
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Crazy Problem
@bpn7rap wrote:I recently went to AT&T 5G Air for my Internet. Problem is VPN's will not work with their Router and the speed goes down to very close to nothing. I can connect my Nighthawk Model RAX70 to the AT&T Router by cable and I am wondering since I will be connected to my Nighthawk Router if I will once again be able to use a VPN. Thanks for any help or suggestions.
Information on configuring the AT&T fixed wireless devices appears to be scarce. You are looking for documents on how to configure the device for bridge mode to allow use of your router. The documents are available only to the account holders.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
