- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DLNA server keeps getting dropped for Harddrive connected to router USB port
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried to figure this out with technical support both through email and on the phone. I'm almost 100% sure that the email responses are coming from a bot. The messages are completely unhelpful and seem to only vaguely be related to my questions. The phone wasn't much better. The "expert technicians" tried to tell me that I needed a seperate device for port forwarding and dlna is not supported on my router. So maybe I'll get some help here.
The issue that I'm having is that I can start a dlna server on my router using the usb port and external harddrive (NTFS formatted). I set it up and it shows up on my home devices. I can play the videos and all looks well but within anywhere between 15 minutes and an hour it disappears from all of my devices. I have 2 Rokus, 3 computers, and an Oculus Quest so this is not related to any single device. The DLNA disappears everywhere. If I go onto a web browser and enter the router settings page I can rescan the media files and usually this will make the DLNA server appear again until the process repeats. I reset the router to default settings and set everything up again with the same result. Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DLNA server keeps getting dropped for Harddrive connected to router USB port
After couple of hours the Dlna simply dissappear
I have to go to the config.. Rescan and then I can use it for a while.
It is driving me crazy... I used to have a Nighthawk X4S with no problem at all for DLNA.
I hope is a firmware problem but I read that the RAX120 doesn't have the problem (Qualcomm chipset) it but the RAX200 has the same issues (Broadcom chipset... Same as the Rax80)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was never able to get it to work. I ended up getting the RAX120 which was on sale for the same price as the RAX80 and everything works now. Now if only I could retrieve all my lost time. 😉
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
