× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Disable Wireless Isolation on RAX80
Tim9449
Follower
I need to disable wireless isolation on my router according to Logitech so that a Harmony Remote Hub can be set up. Not sure how to do this.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 3
Christian_R
NETGEAR Employee Retired
Re: Disable Wireless Isolation on RAX80
Hi Tim9449,
I would recommend checking out an older post that may help resolve your issue.
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX80-very-inconsistent-discovery-...
Christian
Message 2 of 3
GabboCH
Apprentice
Not really sure that turning off SmartConnect is a "solution" rather a "workaround" for a problem in the netgear routers..?
Message 3 of 3
Discussion stats
  • 2 replies
  • 833 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
