- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Dual Wan on the AX8 or AX12
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok heres my problem, i have 2 ISPs at home each with 1gb connections, i want to dual wan them. these new AX routers have one multi gig port, great. however, can the multigig port can only be used as a WAN port? then thats a deal breaker...
someone tell me if its possible to use 2x1gig WAN ports and assign the 5G multi-gig port as a LAN, that way i can accept dual wan isps each with 1gig and send to my PC at 2gigs
unless advanced tomato comes out for these new routers then i can assign WAN to any ports i want and make any ports LAN
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Dual Wan on the AX8 or AX12
the Multi-Gig port is only available as a LAN port for the moment.
The option of using this Multi-Gig port as a WAN port may be implemented in the future
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok perfect thats what i want, multigig LAN. is this for both models? so can i change one of the regular gigabit LAN ports into WAN? that way i can have dual gigabit WAN + multigig LAN
- Mark as New
- Bookmark
- Subscribe
- Permalink
4 Ethernet ports: LAN (2 of them can be aggregate)
1 Ethernet port: WAN
1 Multi-Gig port: LAN
that is what is available on both units
One thing to keep in mind though is having the option to create a LAG from a RAX80/RAX120 to a modem does not mean that you can receive 2 different internet connections to the RAX80/RAX120.
It means that you can bond 2 Ethernet cables together between the ISP modem and the router in case you receive more than 1Gb on your internet connection and do not want to waste any bandwidth.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
