× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
FW V1.0.4.76_10.1.82, R8000 - static IPs not being handed out as configured
Dauhee
Hi,
I have static IPs assigned but some are not being handed out - has anyone else seen issues? The IPs that are not being set are for devices passing through EX7000 extender - yes I am using the virtual  MAC as that is what the R8000 sees. It seems to be intermittant which is screwing things up for me. They will work fine then get a different IP that is not the one I have set.
I have tried rebooting both router and extender
Message 1 of 8
Guru
Re: FW V1.0.4.76_10.1.82, R8000 - static IPs not being handed out as configured
Static IP addresses on set ON devices. IP address Reservations are set ON the router.
Has this been a problem recently or has this worked up to a certain point then failed?
Message 2 of 8
Dauhee
yes thats it, configuration regarding reservation of IP set in "LAN Setup" against specificied MAC addresses is not being adhered to.
This functionality worked without issue on DD-WRT, I have just recently put stock V1.0.4.76_10.1.82 on and am experiencing the issue
Message 3 of 8
Guru
Might revert FW version to something prior. Resent FW has not been good for users.
Message 4 of 8
Dauhee
Thanks, I'm going to Open-WRT as Netgear FW updates appear to be problematic and couldn't be bothered spending the time rolling back to old insecure versions.
Message 5 of 8
Guru
Good Luck.
Message 6 of 8
Dauhee
Thanks. I couldn't get 5Ghz wifi to work with OpenWRT.
I tried a November 2020 DD-WRT which bricked it. The older Kong version that worked for me up to now (very well I must add) was from Nov 2019.
So reflashing via serial and going to have to go back through each older version of stock and if I find one that is from 2020 I'll use that, otherwise will go back to what I had.
Message 7 of 8
Guru
Message 8 of 8
Discussion stats
  • 7 replies
  • 1514 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
