× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Installed sax50s router in home. All devices connected but laptop. Laptop located all neighboring wi
Wmlberryhill
Tutor
Laptop will not recognize router. It locates all other networks in area. Any suggestions
Message 1 of 7
Accepted Solutions
Wmlberryhill
Tutor
Re: Installed sax50s router in home. All devices connected but laptop. Laptop located all neighborin
Thank you very much for your help
Found wifi card on computer and opened tab. Went to driver file and there was a button to update driver. After updating everything is working fine.
Message 6 of 7
All Replies
Guru
Not sure what SAX50's are. Maybe you mistyped a model number?
What laptop is it?
what wireless card is in the laptop?
What driver is installed for the wireless card?
Message 2 of 7
Wmlberryhill
Tutor
Model is RAX50S
Computer is older Sony VAIO
Not sure of wifi card or driver
Message 3 of 7
Guru
@Wmlberryhill wrote:
Model is RAX50S
That wifi driver and card is key as some of the older wifi cards have issues seeing wireless AX.
Go to your device manager on the computer. It should list what your wireless card is. From there you can look up your driver.
Then go to the device manufacturer for the wirelss card (not sony) and download and install the latest driver.
Message 4 of 7
Wmlberryhill
Tutor
Thanks. Will try when get back to computer
Message 5 of 7
Wmlberryhill
Tutor
Message 6 of 7
Guru
Glad it was a simple fix!
Message 7 of 7
Discussion stats
  • 6 replies
  • 1137 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
