× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
My rax200 is stuck booting
Paulj1023
Follower
My router is stuck with the amber light and will not finish powering on, I cannot factory reset it nor can I access anything on it
Message 1 of 4
Guru
Re: My rax200 is stuck booting
usually if the power light is amber, it usually indicates a bootup issue or a hardware failure.
You can try recovering it with tftp or nmrpflash.
Are you on Windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walkthrough using a TFTP client. Use the built-in one for Windows 10, though. The video is more of an example of how it's done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Here's a video of nmrpflash: https://www.youtube.com/watch?v=qxQu3wtpFYo
Message 2 of 4
Guru
Try a 30-30-30 reset on the router...
Message 3 of 4
Guru
Any progress on this?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 460 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
