× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
NAT loopback stopped working (RAX30)
axaxax
I have been happily using my RAX30 to access a server on my home network, but yesterday it stopped working.
I can access the service using a local IP address, but when I use its public domain name or my public IP, I get no response.
curl says:
connect to w.x.y.z port 80 failed: No route to host
It is the same on all machine in my house, but when I disconnect my phone from the wifi so it uses mobile data, the server works perfectly.
Does anyone have any ideas why?
I have tried:
* rebooting the router
* unplugging and re-plugging the router
* downgrading the firmware
but none of them help.
Thanks for your help!
Message 1 of 3
Accepted Solutions
axaxax
Re: NAT loopback stopped working (RAX30)
Of course, as soon as I posted this I found the problem!
NAT loopback was working fine, but the local IP address of my service had changed, so my port forwarding rule was pointing to the wrong IP.
I have added an address reservation under LAN Setup to prevent this happening again.
Message 2 of 3
All Replies
axaxax
Message 2 of 3
Guru
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 833 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
