× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
NightHawk RAX80 Remote desktop to local PC running VPN
GPT999
Follower
Recently got the RAX80 to replace my old router.   No problems before that.  I have several PC's at home and I can usually remote desktop to them.  Now I cannot remote desktop to a PC that is running VPN.  Connects if I turn off the VPN on the remote pc.  ANy ideas?  This worked just find with my old router...
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: NightHawk RAX80 Remote desktop to local PC running VPN
Hello GPT999,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 536 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
