× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk AX4200 Galaxy Won't Connect 5 Ghz
SteveMetz
Follower
I just installed a Nighthawk AX4200 and updated to latest firmware. My Samsung Galaxy S21 will connect to the 2.4GHz band but not the 5GHz band. When I try to connect it just spins and times out. My iPad connects fine to the 5GHz band.
Thanks for any ideas.
Message 1 of 2
microchip8
Master
Re: Nighthawk AX4200 Galaxy Won't Connect 5 Ghz
AX4200 is a speed, not a router model. Which router model do you have? Which firmware version (not "the latest" but a number).
Have you tried non-DFS channels on the 5 GHz band?
Message 2 of 2
Discussion stats
  • 1 reply
  • 468 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
