Orbi WiFi 7 RBE973
Reply
Nighthawk AX8 NTP settings not retained
JeffLewis
I just received this router and while browing through the settings I noticed that the time and date were incorrect. After setting the correct time zone and applying changes it was still showing International Date Line West and should be Pacific Time. Also changed NTP server but it still defaulted to Netgear. Not a deal breaker but it would be nice to have the correct time stamps on the event log.
Thanks in advance.
Firmware version: V1.0.3.98_1.0.46
Hardware: RAX75
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 5
Christian_R
NETGEAR Employee Retired
Re: Nighthawk AX8 NTP settings not retained
Hi JeffLewis,
I have a trial firmware that may help resolve your issue. If you're interested, please send me a private message with your email address and serial number.
Christian
Message 2 of 5
JeffLewis
Hello,
After upgrading firmware to V1.0.3.102_2.1.46.1, the current time is now correct but the router will still not accept changes to time zone and/or new NTP server settings.
Thanks!
Message 3 of 5
Christian_R
Hi JeffLewis,
May you perform a factory reset on the router after updating the firmware.
Christian
Message 4 of 5
paperbag
Tutor
I have the same issue.  The settings are default back to "International Date Line West".  It won't let me set to "Pacific Time (US & Canada); Tijuana".  In my screenshot, I am running as Access Point but this issue happened no matter what I set it to (primary router or access point).  When I flashed back to v1.0.3.88, the issue goes away.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 870 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
