× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk router - Circle 1st Gen
melmurrhee
Follower
Just bought this router and started the Circle 1st Gen app.  I set up the bedtime and for what ever reason my internet does not come back on at the wake up.  I have to literally rebood the router to get it to come back on.  Is there a way to correct this.  Please help!
Mel
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Nighthawk router - Circle 1st Gen
Hello melmurrhee,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
http://www.netgear.com/support/contact.aspx
Christian
Message 2 of 2
Discussion stats
  • 1 reply
  • 480 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
