- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Port Forwarding settings don't save (RAX75)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just bought a new Netgear Nighthawk AX8 (RAX75) and I can't get my Port Forwarding selections to save. I log into the router, go to Advanced, and select "Port Forwarding / Port Triggering". When I enter my settings, they appear to save, but are lost after a reboot. When I check externally, the ports show as closed. Any ideas?
I tried to open a support ticket, but that has a problem, too. Despite registering the new product yesterday, it says "Your complimentary 90 days technical support expired on 2019-10-29.", which is 90 days into the future! Any ideas on that, as well?
Thanks for any help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port Forwarding settings don't save (RAX75)
I finally got the port forwarding settings to save in the router, but they have no effect. I opened a port (now shows open) and disabled UPnP, which should close the port.
However... an nmap scan shows that the UPnP port is still open and the ports I'm trying to open as closed...
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are the same ports or overlapping port ranges with the UPnP PMP involved?
Not convinced these consumer devices will lose and properly "reset" the UPnP PMP ports on disabling the service. A reboot might be required.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No. The ports I'm trying to open are different from the UPnP port number.
What I've determined so far is that the Nighthawk web UI falsely reports my desired actions (opening some ports & closing another) as successful. I have verified (using nmap) that the port configurations remain unchanged.
This seems like the simplest use case that should have been caught during QA.
Netgear (@netgear), I am still within my 90-day support window. Can I please get a reply?!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi McCown - I have sent a follow up to support last week and I believe they have been in contact with you. Please feel free to reach out if I can be of any further assistance.
~Christian
