× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX 200 blocked region
C4mth4
Hello everybody,
I bought an used RAX200 and when i plug it i discover the region is blocked at "United States", but i want to change to France.
(Sorry for my bad english)
Thanks for your answer
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 10
Altsai
NETGEAR Expert
Re: RAX 200 blocked region
if you purchase NA SKU, the wifi region would be gray-out according to FCC regulation law.
Model: A6100|WiFi USB Mini Adapter, RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 2 of 10
C4mth4
Hello @Altsai,
I don’t know what is « NA SKU » but yes, the WiFi is gray out. Can I change it with telnet or other? I can’t access to telnet on this model in debug mode?
Message 3 of 10
Christian_R
NETGEAR Employee Retired
Hi C4mth4,
If you purchased a North American RAX200, the WiFi region would be grayed-out according to FCC regulation law. Therefore, you will not be able to change the region.
Christian
Message 4 of 10
C4mth4
Hello @Christian_R , thanks for answer.
I see other router can acces with telnet for change region, not on the RAX200 ?
Message 5 of 10
psychopomp123
Luminary
OP, Try installing TelnetEnable on your pc, and if you can successfully telnet into the RAX200 then use burnsku command to change the router's region to WW (world wide).
https://github.com/insanid/NetgearTelnetEnable
Message 6 of 10
psychopomp123
Luminary
Message 7 of 10
Do people really need to install third party software to enable Telnet on the RAX 200?
You can do this on some other Netgear routers without adding anything.
Just login to:
http://routerlogin.com/debug.htm
then enable Telnet and take it from there.
Message 8 of 10
C4mth4
Message 9 of 10
C4mth4
Thank You @michaelkenward , but i haven't case for enable telnet in debug mode 😞
Message 10 of 10
Discussion stats
  • 9 replies
  • 3922 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
