× NETGEAR would like to hear from you about specific features so we can improve your experience. To participate in this survey please click HERE.
Reply
RAX120 Configuration and firmware
BobSwitz
Greetings,
Does anyone have firmware ver. and configuration settings that work well all I want is screaming fast wifi with no buffering?
I have spectrum with 400Mbps.
 I just purchased the RAX120 since I've been using Netgear routers for may years.
Well I have been very disappointed in the performance, I loved the initial speeds on Wifi but my devices keep disconnecting, apparently a common issue.
My initial wifi speeds were in the 450 - 460Mbps range, but streaming on wifi I get the buffering and no connection symptoms.
Could only reach a chat support person who had me make configuration changes to the router, reboot Cable modem and Router which made my speed drop down to 24Mbps.
I backed out some of the changes until I got back to 450 - 460Mbps range, but still get buffering etc.
I'm on the verge of returning.
I would truly appreciate any help.
Bob
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 7
thehypnootoad
Luminary
Re: RAX120 Configuration and firmware
Drop the 5ghz down to hx80 from 160 do router reboot from button see how it goes.
Message 2 of 7
thehypnootoad
Luminary
HT 80 from HT 160
Message 3 of 7
BobSwitz
Thank you for the suggestion I will try it this weekend when I get home.
I also noticed every  morning when I check the log it says up time for the router is anywhere from 1hour to 3.x hours I don't believe it should be going down every night.
Thanks again.
Bob
Message 4 of 7
thehypnootoad
Luminary
Whats the log saying so can tell if its not a isp drop from modem or a router reboot. Usual questions & answers.
Are you on the latest firmware? If so how did you upgrade did you try a pin hole reset ?
Message 5 of 7
BobSwitz
Even if the ISP did drop that wouldn't necessary cause the router to reboot would it?
I can't check this till the weekend.
Thanks for the help, Bob
Message 6 of 7
thehypnootoad
Luminary
Not normally but it is Netgear if that carries on I would try a pin hole reset and see if that sorts it if not try reinstalling software again via lan (ethernet) then when all up running do another pin hole and start fresh.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1098 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
