- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX120 V2 Constant Random Reboots
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120 V2 Constant Random Reboots
I'm back to comment more after switching from Xfinity 200Mbps to Sonic 10Gbps.
Serial: 6JY
Hardware Version: RAX120v2
Firmware Version: V1.2.8.40
Xfinity 200Mbps + ARRIS SB6190 (using the Internet WAN ethernet port)
I ran NordVPN for about 1hour on my main PC pulling 2-3 Mbps. The router would reboot 5-10 times over 60 minutes, sometimes back to back reboots.
Sonic 10Gbps + Adtran SDX662v (using the Multi Gig 5G ethernet port)
I ran speedtests on speedtest.net and fast.com and noticed that fast.com causes the router to reboot about halfway through the upload test. Happens almost every time I run a test. I ran NordVPN for 30min or so pulling 2Mbps without issue. But up/down 400Mbps seems to guarantee a reboot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can i please have the beta please
Serial Number 6JY
thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What mode is the modem in? Bridged?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
Try option #2 first...
@zdzisko wrote:
cisco epc3925
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes modem is in bridge mode. I have a public Ip on wan
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will you send this beta firmware so that netegar doesn't restart for me?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:
I did. Check you inbox here in the forums.
Reference to an "inbox here in the forums" is puzzling. It may, or may not, be a reference to a "private message".
Look at the top right hand corner of the browser window.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Serial: 6JY
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem is a Motorola MB8600
Router is a 120V2 Serial Number 6JY2....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
May I have the beta FW? My serial starts with 6K0. Encounter the same constantly rebooting issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would also like the beta firmware
- Serial Number: 6JY
- Modem: CM1100
- Service provider: Spectrum
Thanks,
Allan
- Mark as New
- Bookmark
- Subscribe
- Permalink
After more than two months of testing on the beta firmware, I can confirm the beta firmware also solves my RAX120v1 issues (fw 1.2.8.40). My RAX120v1 (with fw 1.2.8.40) always becomes unstable or even loses Internet connection (both wired and wireless) due to overheat. It usually happens within in few days after a reboot.
The beta firmware makes the option "Always enable fan" work on routerlogin.com/debug.htm page. The fan never spins in current released version (fw 1.2.8.40). In the beta firmware, I also have to turn on the option "Always enable fan", otherwise, RAX120v1 still reboots every few days automatically.
My setup:
modem: CM2000
router: RAX120 (v1) with fw: 1.2.8.43-rc
ISP: COX
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please also send me the info on the beta firmware to solve the reboot problem.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry, The beta is specific for v2 model routers.
@chaosminionx wrote:
Please send me the beta firmware for the reboot fix. I am on v1 and would like to test this based on positive feedback from offer v1 users.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Whats the first 3 characters of your routers serial number please.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the v2 model ... please send me the firmware update.
Info: RAX120-100NAS v2 Serial # 6JY21 ....
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My RAX120V2, serial: 6JY2165
