- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX120 router - SSD file transfer slow with 5gbe ethernet connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello everyone,
I recently purchased
1. RAX120 AX6000 router (connected to CM1200 cable modem with monoprice CAT8 ethernet cable)
2. 15 feet Monoprice CAT8 ethernet cable connects the RAX120 router multigig port with the 10/5/2.5 gbe port of the thunderbolt 3 dock below.
3. Akitio Thunder3 Pro Dock (this has 10/5/2.5 gbe ethernet connection interface).
4. Samsung T3 500 gb SSD connected to RAX120 router through USB 3.0 port.
All this set up is connected to my 2016 15 inch macbook pro by a thunderbolt cable from the dock above.
I normally get 400 mb/sec when I connect my SSD directly to my computer, however when this SSD is connected to the RAX120 router and 5gbe connection is active through my wired set up, I only get 160-170 mb/sec.
I have all required equipments for full speed 5gbe connection and shouldn't I get 400 mb/sec with this 5Gbe set up through this router? Blackmagic speed test also gives me the same numbers when this SSD is connected to the router.
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tested large file transfer on network with another ssd and top speeds are same around 150mb/sec and there was no speed slow down on the way.
I realized that speed slow down problem is related with my current ssd. I tested my current ssd with a direct connection to my computer and shows the same gradual slow down.
As a result, this router is able to provide around 150mb/sec with fastest hard drives without any geadual slow down. If anybody experience gradual slow down during large file transfer, I recommend them to check their hard drives.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120 router - SSD file transfer slow with 5gbe ethernet connection
Interesting point. I have never tried running speed tests on USB devices attached to a router. It is all just background stuff here. But I would not expect it to match local speeds. Too many things to get in the way.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I wouldn’t expect anywhere near 400 MB/s even wired as I believe it’s peak is 200-250 MB/s for USB storage according to some reviews. You need to realize this is a router and not a high end NAS as it has an ARM Cortex A53 CPU cores and not a high power desktop Intel/AMD x86 or mobile CPU/Chipset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can state that one too often.
@mesencephalon hasn't fallen into that trap, but a lot of people seem to think that a USB device can deliver Ethernet performance, even though a decent NAS box can cost as much as a router, even without an y drives installed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just accept this as marketing falsification for this router then since the speed is not near usb 3.0, even though it is advertised as a usb 3.0 port.
I purchased this router due to existence of 5gbe port and wifi6 features along with usb 3.0 ports on it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No router on the market from any vendor claims you will reach peak USB 3.0 throughput. Also you assuming that because it has a 5Gbps port for some reason USB storage speed should hit close to 5Gbps. Thing is no vendor associates USB capability to wired speeds. If you want faster speeds you need to connect a good NAS to the 5Gbps port, which is pretty much what is expected. They never made any false claims in this regard.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I noticed another problem with large file transfer to the router connected ssd with my set up today.
When file transfer (one 20gb file) into the ssd starts, I get the 120-130mb/sec speed but after a while the speed gradually decreases to 25-30 mb/sec. This does not happen when the ssd is directly connected to my computer.
Is it related to less efficient cpu of the router compared to computer cpu?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@avtella is clearly the expert on these things – thanks for that useful background – but I am puzzled that you expect a "remote" USB port to come anywhere near a direct connection.
It isn't just the CPU, but the link between the PC and the router and then the link between the router and the USB device. Both links require data handling to check for corruption and to account for other things that are happening along the same connection.
Your USB to PC link is a dedicated connection. There can be any number of things sending simultaneous traffic along a single cable on a network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could be the same thing. When copying a file, the operating system is doing all sorts of checks to guarantree the integrity of the data.
There is so much going on that it slows down the process.
You might be able to improve things by tweaking stuff like the buffer size.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How far are you from the router and are there any walls in between? Also try using the latest WiFi drivers from Intel/Qualcomm/Broadcom. At least on the AX200 two of the previous drivers don’t recall which version, were a bit finicky.
One more thing is try with AX enabled and disabled. I know a few people had issues with AX mode enabled a while back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I haven't tried these transfers through wifi, though..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good feedback.
Sound advice.
