× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX120
Loronew
RAX120
My RAX120 drops my fire sticks but maintains a connection to my iPhone, iPad and other 20 devices. If I do a factory reset everything works again but about 2 weeks later the same thing occurs. Can anyone help?
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 9
Christian_R
NETGEAR Employee Retired
Re: RAX120
Hello Loronew,
Have you had a moment to get in contact with Amazon's Fire Stick support team regarding your Fire Stick issues?
Christian
Message 2 of 9
Loronew
Re: RAX120
No. I figured since the problem is temporarily resolved after doing a hard reset of the router that it was a software issue with the Netgear Router. I have 5 fire sticks that all stop working at the same time until I reset the router then they work perfectly again
Message 3 of 9
Christian_R
Re: RAX120
Lorenew,
You may also check to see if your device is due for a firmware update.
Christian
Message 4 of 9
Loronew
Re: RAX120
Firmware is up to date
Message 5 of 9
Newfiedrool
Virtuoso
Re: RAX120
I've a fire stick the 4K version and no issues. Have you by any chance unlocked these devices.
Does your logs show anything as in repeated requests of DHCP for the devices?
Message 6 of 9
Loronew
Re: RAX120
No. I have HULU, Netflix, Disney, Crunchyroll, CBS & WatchTV.
Message 7 of 9
Loronew
Re: RAX120
How do I check the logs?
Message 8 of 9
Newfiedrool
Virtuoso
Re: RAX120
Log into your routers GUI
go to advanced tab, then go to administration and you will see the logs.
Message 9 of 9
Discussion stats
  • 8 replies
  • 1258 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
