× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX20 / AX1800 Firmware readySHARE bug?
microsvc2
Tutor
I have upgraded the firmware on my RAX20 to V1.0.2.82_2.0.52 and it is working EXCEPT that the readySHARE USB LED is not on on ther front of the router.  I can access readySHARE as before but the LED is not lit.  The LED setting is for all LEDs to be on.
Is this a BUG in the firmware or something else?
Thanks!
Bob
BTW: My Router RAX20/AX1800 is not in the Model list above.
Message 1 of 10
Christian_R
NETGEAR Employee Retired
Re: RAX20 / AX1800 Firmware readySHARE bug?
Hello microsvc2,
May you factory reset your router and let us know if your issue persists.
Christian
Message 2 of 10
microsvc2
Tutor
I assume I will lose all my changes, is it OK to export my config and import it after reset?
Message 3 of 10
Christian_R
Hi microsvc2,
Yes, you may do that.
Christian
Message 4 of 10
microsvc2
Tutor
Well, I reset the router as suggested.  The USB LED did not come back on.  So I restored the config and still no USB LED.  I'm convinced this is a firmware BUG.  How can we get this fixed?
Bob
Message 5 of 10
microsvc2
Tutor
Is there any Netgear techs out there that can verify this and get it fixed?
Message 6 of 10
Christian_R
Hi microsvc2,
I'd like for our support team to reach out for further investigation. May you send me a private info with your email, phone, and serial number.
Thanks,
Christian
Message 7 of 10
Retired_Member
Not applicable
Hi microsvc2,
I recently purchased the Netgear RAX20 router, and faced the same issue as yours after upgrading the firmware to V1.0.2.82_2.0.52. I wanted to know if your issue has been resolved and if yes, then how?
Thankyou.
Message 8 of 10
microsvc2
Tutor
No, this is not resolved.  I spoke directly with an engineer in Tiawan (I think) and he said this should be fixed in the next firmware release.  I just went back to my previous release for now and am watching for a release higher than 82.  It's been months already. Apparently not a priority.
Message 9 of 10
8tailsCAT
Initiate
I also encountered this problem, the ReadyShare function is normal, but the USB light is not on.  When the next firmware update will be release? It is already 3 months passed. Waiting for it
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1852 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
