× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX200/AX12 - Blocking Schedule not working.
Des73
Hi Guys,
I have the same old problem of the schedule to block devices not working on my new RAX200/AX12.
I have trauled thro this site, but havent found the answer.
I have tried everything I have found, but mostly i have already tried it.
This issue has been bugging me for months and I have a nocturnal child who is failing to function in the real daytime world.
If I have missed the answer, please, please let me know.
I have a new RAX200 (Latest firmware)
Static IPs are set for my sons 2 devices (They are the same IPs every time he connects).
Schedule setup for 01:01am to 07:01am
Access Control setup to not allow new devices to connect.
Why is it not working?
Had same problem on my previous R7000
It seems if I reboot it kicks in and works, if I do nothing or he does nothing after 1am his connections continue to work.
(It worked for the first night then failed, or he was humouring me).
I applied the schedule to my own phone but it didnt work at the set times unless I left the network and rejoined.
This is driving me nuts.
Any help would be so apreciative and valuable.
Cheers.
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: RAX200/AX12 - Blocking Schedule not working.
You may want to look into using parental controls https://www.netgear.com/home/services/circle-smart-parental-controls/
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 717 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
