× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX200 Firmware Version 1.0.2.88 breaks ipv6
RajaDaja
Luminary
Hello,
RAX200 Firmware Version 1.0.2.88.  Breaks ipv6 ! Is this suppose to be?
Model: CM1000|Ultra-High Speed Cable Modem—DOCSIS® 3.1 Ready, R9000|Nighthawk X10 AD7200 Smart WiFi Router, RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 10
RajaDaja
Luminary
Re: RAX200 Firmware Version 1.0.2.88 breaks ipv6
While fiddling around with ipv6 settings , ipv6 for WAN indicated ‘Not available’
Noticed the LAN ipv6 took, but not having ipv6 the way I normally see it configured. I downgraded back to previous firmware.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router, RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 2 of 10
Christian_R
NETGEAR Employee Retired
Hi RajaDaja,
Thanks for the feedback. Were you able to perform a factory reset after the firmware update?
Christian
Message 3 of 10
RajaDaja
Luminary
Yes, right after firmware update. Still no ipv6 configuration. IPv6 test fails . Online gaming shows ipv4. Use to show both . I guess I’m not missing much without ipv6. Oh well???
Message 4 of 10
crm813
Initiate
I am having similar problems with the IPV6 disappearing after the latest firmware upgrade.  The problem is that the updgrade includes many features that make my many IoT devices connect consistently to the router. My iPhoneXsMax connected to the router shows 2 IPV6 addresses, but my desktop and iPad do not.  I also have an EAX80 hardwired to the router using CAT6 cabling as an AP for the upstairs - it also does not show an IPV6 address.  The Xfinity .  This is really frustrating that after spending $850 for these high end devices, all I get is a new problem.  I installed the prior firmware on the routr, power cycled the cable modem several times (and between the set ups), reset the router and reconfigured things manually (not using a backup), and then upgraded, rest the router and updated things manually - I have spent way too many hours trying to get this high end equipment to function.  PLEASE RELEASE A TESTED, FULLY FUNCTIONAL FIRMWARE UPDATE.  PLEASE. I AM SO FRUSTRATED.
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 5 of 10
RajaDaja
Luminary
I totally agree with you. Netgear firmware is riskier than ever. I want ipv6 functionality, it provides a more optimal gaming experience So I am currently on 1.0.2.8 firmware where I have ipv6 throughout my network of +30 devices. Still issues but tolerable......
Message 6 of 10
rinthos
Luminary
Just wondering if any updates for this?  Recently purchased an RAX200, and could not get it to pick up an IP from our business ISP.
Returned/Exchanged the router and no-go. Contacted support again and the answer is known issue, find another way to get internet access working or get a different router...not cool. So that's 2 being returned/sent back.
Anyone have any updates on a fix or firmware to use or other workaround?
Just as a sanity check, I also tried with firmware: https://kb.netgear.com/000062038/RAX200-Firmware-Version-1-0-2-92-Hot-Fix
But still cannot pick-up an IPv6 address.  Put in our R8000P and a Linksys EA8300 and both are able to aquire IPv6 addresses, so it's not my ISP, definately this device/firmware.
Message 7 of 10
RajaDaja
Luminary
Hi,
Private message Christian_R
Provide the S/N with a brief summary of your ipv6 issue of your RAX200. He’s Netgear Mod. He will help you.
Message 8 of 10
rinthos
Luminary
Ok thanks, will send him a PM him now w/ those details. Thanks.
Message 9 of 10
RajaDaja
Luminary
While you're waiting,
From my experience, F/W  V1.0.2.8_1.0.45  is the most stable with ipv6 functionality. Been on it for a while. Tried all the F/W available, even one from Netgear Mode, which by the way, work great for a while then the internet just froze while working. I panicked and did a quick F/W downgrade back to.........you guessed it.....V1.0.2.8_1.0.45. Been good ever since. I have Auto update disable. Good luck
Message 10 of 10
Discussion stats
  • 9 replies
  • 2031 views
  • 5 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
