× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX50 download firmware update
aaodao
Follower
I am trying to update firmware but get message of error when checking for new firmware. I have v1.0.2.82. Does someone know how to fix this? This router has been a nightmare!!
Message 1 of 2
Guru
Re: RAX50 download firmware update
You can  manually install it. Its usually the method I recommend is a manual firmware update over a hardwired connection.
Reason why is when we see corrupt firmware issues, it tends to be when updated over wifi or via the app.
You can get the firmware at the support site. Extract it and then follow the manual firmware update process.
https://www.netgear.com/support/product/rax50
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 734 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
