× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX70 DNS cannot be resolved
RickWu
Tutor
Hi Netgear
In RAX70 DNS using "ISP dynamic acquisition" or "manual setting", the device I have on hand often fails to resolve DNS, and the DNS must be set on the client device to resolve it normally. I saw that other WIFI devices in the forum seem to have problems with DNS failure. , Can it be solved, or can I let DHCP add DNS delivery to solve it? If I keep setting manually from the client device, I feel sad that Netgear will not buy it next time.
Message 1 of 4
Christian_R
NETGEAR Employee Retired
Re: RAX70 DNS cannot be resolved
Hello RickWu,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 4
RickWu
Tutor
A case has already been opened. It seems that many people in the forum have these problems, but you don’t pay much attention to this problem.
Message 3 of 4
rubensz
Tutor
I've tried 2 RAX70 bought from Amazon. Both same bad experience.
Probably I will return it to amazon as the 1st one (sent back because I thought warehouse issue), not sure I will try to bought the 3rd, it is really insane activity.
Please Netgear give a kind of solution. thanks
Message 4 of 4
Discussion stats
  • 3 replies
  • 945 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
